[Qgis-developer] Why is scrolling in the attribute table so slow?
Nathan Woodrow madmanwoo at gmail.com
Fri Dec 2 02:40:14 EST 2011
+1 to local cache as Select at ID would just confuse people.
- Nathan
On Fri, Dec 2, 2011 at 5:28 PM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> Fyi - Jürgen just included an option in the Postgis Table Connection
> dialogue allowing to cache a Postgis table or view locally. There is a
> separate column called "Select at ID" (german "Abfrage nach ID") which is
> checked by default. If you disable this checkbox it will activate "local
> caching" of the table data. Of course this is limited to the amount of
> memory you have in your machine, but it is great improvement for slower
> Postgis views or slower connections.
> Please try it out and report bugs, if any.
> I am not yet fully convinced if people understand what "Select at ID"
> means ... any suggestions? It is derived from the fact that if a provider
> has getFeatureAtId available it will not cache locally, otherwise it will.
> I would prefer "local cache" as a column name, but then the meaning of the
> checkbox would have to be reversed.
> Andreas
> On Thu, 24 Nov 2011 15:44:35 +0100, Andreas Neumann wrote:
>> thats interesting - the same table in Spatialite or Shape scrolls much
>>>> faster (at least 10 times faster)
>>>  so yes - it seems to be related to the PostgreSQL datasource.
>>> (commit) 90481072 might help with this a bit.
>> it helps for repeated scrolling. Initial scrolling is equally slow
>> than before, but if I scroll back and forth to records that had
>> already been viewed, it scrolls faster.
>> Thanks, Jürgen!
>> Andreas
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111202/b249fdcf/attachment.html
