[Qgis-developer] Crash when adding an image to the print composer
Werner Macho werner.macho at gmail.com
Wed Dec 7 11:48:28 EST 2011
Seems that the fix is already in upcoming 1.7.3 which i am running for
testing purposes..
Thanks a lot.. gotta check the commit
Regards Werner
Am 07.12.2011 17:21 schrieb "Andreas Neumann" <a.neumann at carto.net>:
> Werner - I just tested with OSGeo4W 1.7.2.1 on Windows and the problem
> still exists if you set project properties to "relative paths".
> Here is the commit with the fix that needs to be backported:
> https://github.com/qgis/**Quantum-GIS/commit/**
> 917f748d33d4a41f700e744c9b5479**2e4355257a<https://github.com/qgis/Quantum-GIS/commit/917f748d33d4a41f700e744c9b54792e4355257a>
> Thanks,
> Andreas
> On Wed, 7 Dec 2011 17:09:00 +0100, Werner Macho wrote:
>> Hi
>> I just tried to add a Image to the Print composer in upcoming 1.7.3
>> without any problem .. So I'd say probably this is not a problem in
>> 1.7.x
>> But I could also do something "wrong".. Just adding a jpg as image to
>> print composer works in my case
>> regards
>> Werner
>> On Wed, Dec 7, 2011 at 4:42 PM, Andreas Neumann <a.neumann at carto.net>
>> wrote:
>>> Hi,
>>> Yes - I ran into the same problem.
>>> Question: is the bug also in 1.7x? If yes, the fix would have to be
>>> backported? I agree it is a major bug, if it also exists in 1.7x
>>> Andreas
>>> On Wed, 07 Dec 2011 15:22:14 +0100, Marco Hugentobler wrote:
>>>> Hi Paolo
>>>> Is that on current master from today? I remember having fixed that
>>>> last friday.
>>>> Regards,
>>>> Marco
>>>> On 07.12.2011 15:18, Paolo Cavallini wrote:
>>>>> Hi all.
>>>>> I got a sytematic crash when adding an image to print layout:
>>>>> Fatal: ASSERT: "!isEmpty()" in file /usr/include/qt4/QtCore/qlist.**h,
>>>>> line
>>>>> 274
>>>>> I kind of remember this was raised recently.
>>>>> I think this is a crucial issue, to be fixed ASAP, and is a recent
>>>>> regression.
>>>>> All the best.
>>> Andreas Neumann
>>> Böschacherstrasse 10A
>>> 8624 Grüt (Gossau ZH)
>>> Switzerland
>>> ______________________________**_________________
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Andreas Neumann
> Switzerland
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111207/e39fe756/attachment.html
