[Qgis-developer] Georeferencer produces wrong (shifted) result
Manuel Massing m.massing at warped-space.de
Wed Dec 14 17:26:29 EST 2011
Hi Agus,
> Cannot download http://www.warped-space.de/Ilerfly125v2_modifziert.tif,
> I get:
> Oops! This link appears to be broken.
sorry, the correct link is
	http://www.warped-space.de/Ilerfly125v2_modifiziert.tif
> The procedure we follow is:
> 1. Set project to CRS EPSG:23031
> 2. No On the fly reprojection
> 3. Start georeferencer and open ilerfly125v2.tif and its points file
> with the settings displayed
thats correct, and I did exactly the same (except for the scale change - might
be worth checking out), but couldn't reproduce the shiftr (my results match
the output of the arcgis version).
I've got a lot on my plate right now, but if I find the time I'll try to look
this is a regression in qgis or the georeferencer, as I said I'm still on 1.7
atm.
How do the residuals look in the georeferencer? Is there a noticable bias
(i.e. do they all point in one direction?)
Also, make sure there was no world file influencing the unreferenced file
(something like Ilerfly125v2.wld), the georeferencer can't handle that.
I also noticed that you used a scale change, does the shift also appear
without scale change?
cheers,
	Manuel
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111214/6520fd47/attachment-0001.html
