[Qgis-developer] Where to put plugins and documents ?
Alexander Bruy
alexander.bruy at gmail.com
Thu Dec 15 10:28:46 EST 2011
Hi
2011/12/15 "FERRATON Alain (Chef du groupe informatique technique et
scientifique, responsable du pôle national d'expertise progiciels
géomatiques) - SG/SPSSI/CPII/DOO/ITS"
<Alain.Ferraton at developpement-durable.gouv.fr>:
> We want to provide two plugins (experimental status).
> What is the proper way to proceed, given the current plugins reorganization ?>
You can upload your plugins to the QGIS Contributed repo [0] or to the new
plugins repo [1]. In second case you need an OSGeo ID [2].
> Is there a recommendation to share the sources (such as
> http://hub.qgis.org/projects/plugin-builder)?
To share plugin sources you can use any SCM service such as GitHub, BitBucket,
Google Code etc, or even setup own repo. AFAIK there are no strict
recomendations
on this.
> We also have QGIS documentation (in French) that might interest the
> community. Where to publish?
For this question it is better to contact Otto Dassau (cc-ing).
Alexander Bruy
