[Qgis-developer] Symbol properties dialog from plugin
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Dec 22 01:50:11 EST 2011
Thanks Marco, that worked!
I first create a symbol using
self.symbol = QgsLineSymbolV2()
And then I can edit it using
QgsSymbolV2PropertiesDialog(self.symbol,self.layer).exec_()
There is only one concern, the rubber band does not accept a full
symbol, only a width and a color. Is there a reason for that?
BTW, I just applied to this list, and I don't really know how to answer
emails as I checked the daily digest option. Does anyone has a tip?
Thanks again,
Greetings,
Denis
Hi Denis
You can use the class QgsSymbolV2PropertiesDialog and pass existing
symbol and vector layer in constructor. Afaik the symbol will be changed
directly, however it is possible to make a backup with clone().
Regards,
Marco
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20111222/66d78040/attachment.html
