[Qgis-developer] Symbol properties dialog from plugin
Andreas Neumann
a.neumann at carto.net
Thu Dec 22 04:13:54 EST 2011
Hi Denis,
The QgsRubberband was never meant as a full-featured rendering of
features. It was made to highlight features (e.g. selected features) or
to quickly draw an overlay.
If you want full-featured rendering you can create a separate layer, or
a temporary MemoryLayer.
Andreas
On Thu, 22 Dec 2011 07:50:11 +0100, Denis Rouzaud wrote:
> Thanks Marco, that worked!
> I first create a symbol using
> self.symbol = QgsLineSymbolV2()
> And then I can edit it using
> QgsSymbolV2PropertiesDialog(self.symbol,self.layer).exec_()
> There is only one concern, the rubber band does not accept a full
> symbol, only a width and a color. Is there a reason for that?
> BTW, I just applied to this list, and I don't really know how to
> answer emails as I checked the daily digest option. Does anyone has a
> tip?
> Thanks again,
> Greetings,
> Denis
>> Hi Denis
>> You can use the class QgsSymbolV2PropertiesDialog and pass existing
>> symbol and vector layer in constructor. Afaik the symbol will be
>> changed
>> directly, however it is possible to make a backup with clone().
>> Regards,
>> Marco
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
