[Qgis-developer] plugin autopackaging scripts
    Giuseppe Sucameli
    sucameli at faunalia.it
    Wed Dec 28 07:35:32 EST 2011
Hi all,
On Wed, Dec 28, 2011 at 11:56 AM, Richard Duivenvoorde
<rdmailings at duif.net> wrote:
>> We (faunalia) have a script for autopackaging our python plugins.
> Can you put it somewhere so we can have a look?
the Faunalia auto-packaging script [1] is executed as a post-commit
svn hook script for the plugins in the Faunalia qgis_plugins trac [2].
It packages the source and copy it to the repository server, but also
update __init__.py version and the repository plugins.xml (on the
repository server) according to some configuration options in a
config.txt file [3].
Of course this cannot be used as it is because we have no svn repos
(Redmine repository instances uses git), but we may do something
similar for git.
> I think the new plugin
> infrastructure does already a good job in testing the plugin contents.
Updating the repository plugin.xml is already done by the new
plugin infrastructure when uploading a new version of a plugin.
> ps I also think it is good if a plugin dev is aware of the exact way of
> packaging: I think it is a learning process for them also.
I agree with you, but making it easier could be a good improvement
also for devs.
Regards.
[1] https://trac.faunalia.it/qgis_plugins/browser/branches/test/autopackaging.py
[2] https://trac.faunalia.it/qgis_plugins/
[3] https://trac.faunalia.it/qgis_plugins/wiki/autopackaging
Giuseppe Sucameli
