[Qgis-developer] QgsMapLayer.getLayerID() ...
Chris Crook
ccrook at linz.govt.nz
Sun Feb 13 14:18:47 EST 2011
Hi
Its just a little thing, but I'm just wondering if there is any feeling about the name of the QgsMapLayer.getLayerID() function, and whether it would be much better to just be called id().
I find the existing name hard to remember, confusing in its capitalisation, and inconsistent with the general naming conventions (for example QgsFeature.id()).
Is there any support for deprecating this member in favour of .id()? Or strong objection for that matter?
Cheers
Chris
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
