[Qgis-developer] New Symbology / OSM/ ICONS
kimaidou kimaidou at gmail.com
Mon Feb 21 03:17:25 EST 2011
Hi Mayeul and devs,
Mayel, I had a look at your wiki page which describes how to get and use OSM
data. I think you should speak a bit more about pre-processed shapefiles, as
it is much easier for people with no server/time/skills to open a shapefile
in Qgis than setting up a complete OSM postgresql/postgis database.
I know all the tags are not in the shapefiles, but it is a good start. See
the small qgis mapserver rendering with these shapefiles :
http://demo.3liz.fr/qgismapserver/
By, the way, I am also looking for icons to render the rich OSM poi
database, (http://demo.3liz.fr/osminterest/ ) and asked the creator of the
SJJB icons to create some more. I gave him a list 2 days ago, and he told me
he would spend some times to work on it in the coming weeks.
I will let you know when I get some information.
Kimaidou
2011/2/19 Mayeul Kauffmann <mayeul.kauffmann at free.fr>
> Thanks for the suggestion Martin!
> Icons are available here:
> http://www.mediafire.com/?344x43313q3xx8n
> They are meant to be used with the tutorial here:
> http://www.qgis.org/wiki/Using_OpenStreetMap_data
> I was hoping to find something without restrictions and if possible
> dedicated to open source material.
> I could not find it here:
> http://wiki.osgeo.org/wiki/OSGeo_map_symbol_set
> There is http://www.openclipart.org (which supports multiple uploads,
> collections and packages) but I cannot upload a zipped file, hence I
> cannot reproduce the folder structure required for qgis to find the
> right files.
> So I've put the icons I'm using on mediafire:
> osm_icons4qgis_v1.zip
> (If I do not login often enough, this might be destroyed).
> All the icons that either SJJB or myself created are copyright free
> (CC-0). I do not know the status of the others (mostly, the others are
> preinstalled with qgis).
> See http://www.sjjb.co.uk/mapicons/introduction
> Mayeul
> Le vendredi 18 février 2011 à 23:40 +0100, Martin Dobias a écrit :
> > There are plenty of web services for easy sharing of files, for
> > example, mediafire.com or megaupload.com
> > Martin
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110221/6d181fcf/attachment.html
