[Qgis-developer] New Symbology / OSM/ ICONS
kimaidou
kimaidou at gmail.com
Tue Feb 22 03:46:02 EST 2011
Thanks for this Mayeul
2011/2/21 Mayeul Kauffmann <mayeul.kauffmann at free.fr>
> Hi,
> I have added (on the wiki) some comments and a link to the 3liz.com demo
> and blog about the qgis mapserver rendering based on shapefiles.
> Mayeul
> Le lundi 21 février 2011 à 09:17 +0100, kimaidou a écrit :
> > Hi Mayeul and devs,
> > Mayel, I had a look at your wiki page which describes how to get and
> > use OSM data. I think you should speak a bit more about pre-processed
> > shapefiles, as it is much easier for people with no server/time/skills
> > to open a shapefile in Qgis than setting up a complete OSM
> > postgresql/postgis database.
> > I know all the tags are not in the shapefiles, but it is a good start.
> > See the small qgis mapserver rendering with these shapefiles :
> > http://demo.3liz.fr/qgismapserver/
> > By, the way, I am also looking for icons to render the rich OSM poi
> > database, (http://demo.3liz.fr/osminterest/ ) and asked the creator of
> > the SJJB icons to create some more. I gave him a list 2 days ago, and
> > he told me he would spend some times to work on it in the coming
> > weeks.
> > I will let you know when I get some information.
> > Kimaidou
> > 2011/2/19 Mayeul Kauffmann <mayeul.kauffmann at free.fr>
> > Thanks for the suggestion Martin!
> > Icons are available here:
> > http://www.mediafire.com/?344x43313q3xx8n
> > They are meant to be used with the tutorial here:
> > http://www.qgis.org/wiki/Using_OpenStreetMap_data
> > I was hoping to find something without restrictions and if
> > possible
> > dedicated to open source material.
> > I could not find it here:
> > http://wiki.osgeo.org/wiki/OSGeo_map_symbol_set
> > There is http://www.openclipart.org (which supports multiple
> > uploads,
> > collections and packages) but I cannot upload a zipped file,
> > hence I
> > cannot reproduce the folder structure required for qgis to
> > find the
> > right files.
> > So I've put the icons I'm using on mediafire:
> > osm_icons4qgis_v1.zip
> > (If I do not login often enough, this might be destroyed).
> > All the icons that either SJJB or myself created are copyright
> > free
> > (CC-0). I do not know the status of the others (mostly, the
> > others are
> > preinstalled with qgis).
> > See http://www.sjjb.co.uk/mapicons/introduction
> > Mayeul
> > Le vendredi 18 février 2011 à 23:40 +0100, Martin Dobias a
> > écrit :
> > > There are plenty of web services for easy sharing of files,
> > for
> > > example, mediafire.com or megaupload.com
> > > Martin
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110222/0f7b9d77/attachment.html
