[Qgis-developer] new plugin repo online
Giuseppe Sucameli sucameli at faunalia.it
Sun Feb 27 19:25:59 EST 2011
Hi guys,
thanks a lot for your work! The new plugin site it's really nice.
BTW, the https login is still missing. I understand it would be one of the
last features
you'll put on.
Do you have a todo list or a roadmap? I'd like to look at it.
Cheers.
On Fri, Feb 25, 2011 at 1:56 PM, Martin Dobias <wonder.sk at gmail.com> wrote:
> On Thu, Feb 24, 2011 at 9:41 AM, Paolo Cavallini <cavallini at faunalia.it>
> wrote:
> > Il giorno mer, 23/02/2011 alle 00.47 -0800, Alex Mandel ha scritto:
> >> That feature has been discussed, is way down at the bottom of the todo
> >> list but is quite possible. We are looking for python programmers to try
> >> and implement it in django if you are interested in helping.
> > I do not quite agree it's a low priority issue: we found the publishing
> > process rather painful, and error prone. We use a bash script for this,
> > it can be used until a py program comes out.
> Probably the easiest way for publishing of plugins would be a python
> script bundled with QGIS which would do it on request:
> publish_plugin.py -user foo -pass bar  my_plugin
> That would zip the "my_plugin" plugin from your local working
> directory, sign you in the qgis repository, upload the plugin and
> print the result (success / error). Such a script can be done very
> quickly, right? Eventually a plugin could do this job, remembering the
> username/password, so publishing a new version of a plugin would be a
> one-click action.
> Martin
> Qgis-developer mailing list
Giuseppe Sucameli
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110228/6f5b3a0c/attachment.html
