[Qgis-developer] Raster providers
Radim Blazek
radim.blazek at gmail.com
Mon Feb 28 03:01:33 EST 2011
On Sun, Feb 27, 2011 at 9:54 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Do you have anything else left on your todo list before you can merge to trunk?
It looks like this:
qgsrasterprojector.* qgsrasterdataprovider.* raster/qgsrasterlayer.* : 60 TODOs
qgsgdalprovider.*: 11 TODOs
qgsgrassrasterprovider.*: 8 TODOs
qgswmsprovider.*: 53 TODOs
But all those TODOs are not really problem, IIRC, before the merge I have to add
only fall back to precise reprojection if approximation fails (easy)
and code cleanup.
The problem with data reloading on update (G. Manghi reported) I would
like to solve in trunk
because it may need QgsLayer and renderer modifications.
Then, there are some places, usually constants which have
to be checked better (e.g. max error, in reprojection, minimum source
resolution etc.)
That can still be done in trunk, I think.
BTW: The approximate reprojection could may be used also for vectors?
Radim
> +1 from me to merge when you are ready
> I would like to make some cleanups to the raster properties dialog
> after you are done...hopefully I can do the ui clean upsin time for
> 1.7....
> Regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
