[Qgis-developer] Raster providers
Radim Blazek
radim.blazek at gmail.com
Mon Feb 28 14:19:08 EST 2011
thanks for testing, I'll look at WMS again and let you know.
Openlayers are implemented as a plugin, not provider, they will not
become automatically reprojected.
Radim
On Mon, Feb 28, 2011 at 1:12 AM, John C. Tull <jctull at gmail.com> wrote:
> Hi,
> I was testing a little today. It appears that WMS layers are not being projected. I would imagine that needs to be corrected before a merge. Also, openlayers are not correctly projecting based on some quick tests on my end. I'm not sure if this is a problem with the branch or the plugin.
> Cheers,
> John
> On Feb 27, 2011, at 12:54 PM, Tim Sutton wrote:
>> Hi
>> 8<---------snip-------------
>>>> - it would be nice if the 'collar' - the part outside the image data
>>>> area in rotated images was made transparent by default.
>>> Isn't it? The data outside source data extent are null. That is the source
>>> of all the troubles with null values handling and types remapping.
>>> The grey border around the tif you posted is part of the image. Is not?
>> Sorry you are right - the issue lies with my data.
>> Do you have anything else left on your todo list before you can merge to trunk?
>> +1 from me to merge when you are ready
>> I would like to make some cleanups to the raster properties dialog
>> after you are done...hopefully I can do the ui clean upsin time for
>> 1.7....
>> Regards
>> Tim
>> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
>> Please do not email me off-list with technical
>> support questions. Using the lists will gain
>> more exposure for your issues and the knowledge
>> surrounding your issue will be shared with all.
>> Visit http://linfiniti.com to find out about:
>> * QGIS programming and support services
>> * Mapserver and PostGIS based hosting plans
>> * FOSS Consulting Services
>> Skype: timlinux
>> Irc: timlinux on #qgis at freenode.net
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
