[Qgis-developer] Raster providers
John C. Tull
jctull at gmail.com
Sun Feb 27 19:12:15 EST 2011
I was testing a little today. It appears that WMS layers are not being projected. I would imagine that needs to be corrected before a merge. Also, openlayers are not correctly projecting based on some quick tests on my end. I'm not sure if this is a problem with the branch or the plugin.
Cheers,
John
On Feb 27, 2011, at 12:54 PM, Tim Sutton wrote:
> Hi
> 8<---------snip-------------
>>> - it would be nice if the 'collar' - the part outside the image data
>>> area in rotated images was made transparent by default.
>> Isn't it? The data outside source data extent are null. That is the source
>> of all the troubles with null values handling and types remapping.
>> The grey border around the tif you posted is part of the image. Is not?
> Sorry you are right - the issue lies with my data.
> Do you have anything else left on your todo list before you can merge to trunk?
> +1 from me to merge when you are ready
> I would like to make some cleanups to the raster properties dialog
> after you are done...hopefully I can do the ui clean upsin time for
> 1.7....
> Regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-developer mailing list
