[Qgis-developer] Raster providers
Tim Sutton
lists at linfiniti.com
Sun Feb 27 15:54:49 EST 2011
Hi
8<---------snip-------------
>> - it would be nice if the 'collar' - the part outside the image data
>> area in rotated images was made transparent by default.
> Isn't it? The data outside source data extent are null. That is the source
> of all the troubles with null values handling and types remapping.
> The grey border around the tif you posted is part of the image. Is not?
Sorry you are right - the issue lies with my data.
Do you have anything else left on your todo list before you can merge to trunk?
+1 from me to merge when you are ready
I would like to make some cleanups to the raster properties dialog
after you are done...hopefully I can do the ui clean upsin time for
1.7....
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
