[Qgis-developer] Raster providers
Radim Blazek
radim.blazek at gmail.com
Sun Feb 27 14:48:17 EST 2011
On Sun, Feb 27, 2011 at 7:08 PM, Tim Sutton <lists at linfiniti.com> wrote:
> Thanks its working great now. The grayscale issue I was having I can't
> replicate with the data I have here at home - will try again tomorrow
> on my office pc with the original dataset - as far as I know that
> machine is already set to stretch to min->max by default.
Sorry, you were right, after selecting 'stretch to min/max' and apply,
the min max values were set wrongly. Fixed now in GDAL provider
(was missing const, uff).
> From playing around a little on my samsung netbook, I would say
> performance seems quite ok for raster reprojection given the CPU's on
> these machines are slow.
I have done some more optimization today, still not the best but acceptable,
for me, the reprojection takes about 75% of time more.
BTW: compiling as Release, the reprojection time was reduced to about 25%.
> I found two other issues:
> - pyramids tab no long shows options to build pyramids (you can
> replicate with that test dataset I pointed you to).
Fixed. The methods were not virtual, but how on earth it could work before?
> - it would be nice if the 'collar' - the part outside the image data
> area in rotated images was made transparent by default.
Isn't it? The data outside source data extent are null. That is the source
of all the troubles with null values handling and types remapping.
The grey border around the tif you posted is part of the image. Is not?
Radim
> Otherwise its looking great for a merge into trunk soon and being part of 1.7!
> regards
> Tim
>> Radim
> Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
