[Qgis-developer] WktRaster 0.3
Maurício de Paulo mauricio.dev at gmail.com
Wed Jan 5 04:45:41 EST 2011
So your gdal version is prior 1.7.
If you're on windows all you have to do is upgrade osgeo's qgis.
If you're on linux, ubuntugis and debian gis both have 1.7 compiled
repositories.
To get everything right, on qgis there is a description of the providers:
Help->About->Providers. There you can see against witch gdal version your
qgis is working.
Maybe I should say the version on the error dialog.
Best regards,
Mauricio
2011/1/5 Noli Sicad <nsicad at gmail.com>
> I am getting this form dialog error now.
>        Error
> GDAL version incompatible with WktRaster.
> Noli
> On 1/5/11, Maurício de Paulo <mauricio.dev at gmail.com> wrote:
> > I've fixed the bug. It was just a coding issue.
> > If you could reinstall the plugin it shouldn't get the error now.
> > 2011/1/5 Maurício de Paulo <mauricio.dev at gmail.com>
> >> Bug. But still, he's saying your version is too low.
> >> What gdal version are you using?
> >>> I got this error.
> >>> An error has occured while executing Python code:
> >>> Traceback (most recent call last):
> >>>  File "/home/noli/.qgis/python/plugins/wktraster/wktRaster.py", line
> >>> 81, in callAddLayer
> >>>    QMessageBox.warning(self.dlg,"Error", "GDAL version incompatible
> >>> with WktRaster.")
> >>> AttributeError: wktRaster instance has no attribute 'dlg'
> >>> Python version:
> >>> 2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
> >>> [GCC 4.4.3]
> >>> I am using GDAL 1.7.3
> >>> noli at noli-laptop:~$ gdalinfo --version
> >>> GDAL 1.7.3, released 2010/11/10
> >>> What is this error. I don't have a postgis raster yet in my postgis
> >>> installation. Should just disregard this error.
> >>> Thanks.
> >>> Noli
> >>> > It does work with gdal 1.6 or greater.
> >>> > But versions 1.6 and 1.7 are really buggy and can't read irregularly
> >>> blocked
> >>> > data.
> >>> > I've tested on some rapideye imagery now and gdal 1.7 frozen. Testing
> >>> with
> >>> > gdal 1.8 from trunk it runs smoothly.
> >>> > So we have to wait until newer versions are released.
> >>> > Jorge from gdal postgis driver is getting info on the bugs we find
> and
> >>> it
> >>> > should help him develop a more stable gdal driver.
> >>> > I did some testing with a well behaved raster and everything worked
> >>> > out-the-box on windows 7 with gdal 1.7
> >>> > Best regards,
> >>> > Mauricio
> >>> >> Thanks a lot.
> >>> >> Is the plugin works only with GDAL 1.8? I  am reading the changelog.
> >>> >> I am using ubuntu 10.04.
> >>> >> Noli
> >>> >> > Done
> >>> >> >> Thanks for the suggestions!
> >>> >> >> Implementing now.
> >>> >> >> Best regards,
> >>> >> >> Mauricio
> >>> >> >> On Wed, Jan 5, 2011 at 1:55 AM, Noli Sicad <nsicad at gmail.com>
> >>> wrote:
> >>> >> >>> Hi Mauricio,
> >>> >> >>> Thanks for this plugin,
> >>> >> >>> Suggestions
> >>> >> >>> 1. I think it would be good to put this plugin into "Database"
> >>> Menu.
> >>> >> >>> So we can easily find it with the rest of the database plugins.
> >>> This
> >>> >> >>> also prevent the over crowding of the "Plugins" menu.
> >>> >> >>> 2. Then probably "PostGIS Raster" instead of "Add Postgis a
> raster
> >>> >> >>> layer" since you already the same sub menu (i.e. "Add Postgis a
> >>> raster
> >>> >> >>> layer")
> >>> >> >>> 3. Kindly place a changelog file so we know what is new in this
> >>> >> >>> plugin.
> >>> >> >>> Thanks.
> >>> >> >>> Noli
> >>> >> >>> > Hi devs,
> >>> >> >>> > I've updated the wktraster plugin to solve a few issues and to
> >>> >> >>> > implement
> >>> >> >>> the
> >>> >> >>> > data loading gui.
> >>> >> >>> > Now the plugin have an interface to load data to the database.
> >>> >> >>> > I know jorge is going to ask for a few more options on the ui
> >>> >> >>> > but
> >>> I
> >>> >> >>> thought
> >>> >> >>> > that it should be as clean as possible at first. Loading data
> is
> >>> >> still
> >>> >> >>> > a
> >>> >> >>> > non-trivial task so I forced a single use case.
> >>> >> >>> > I couldn't test the gdal version tester as I found my windows
> >>> gdal
> >>> >> >>> version
> >>> >> >>> > is now 1.7.
> >>> >> >>> > At least I could test the data loading and visualization of
> the
> >>> >> utm.tif
> >>> >> >>> file
> >>> >> >>> > on windows 7 (thanks OSGEO4W).
> >>> >> >>> > I hope you enjoy.
> >>> >> >>> > Best regards,
> >>> >> >>> > Mauricio de Paulo
> >>> >> >>> > Engenheiro Cartografo
> >>> >> >>> > MapeandoOBrasil <http://mapeandoobrasil.blogspot.com>
> >>> >> >> Mauricio de Paulo
> >>> >> > Mauricio de Paulo
> >>> > Mauricio de Paulo
> >> Mauricio de Paulo
> > Mauricio de Paulo
Mauricio de Paulo
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110105/da1e9f12/attachment-0001.html
