Re: [Qgis-developer] symlinks in GRASS plugins
cavallini@faunalia.it cavallini at faunalia.it
Tue Jan 11 09:09:29 EST 2011
Thanks. What is the advantage of this approach respect to simply copying it?
All the best.
http://faunalia.it/pc
----- Reply message -----
Da: "Maciej Sieczka" <msieczka at sieczka.org>
Data: lun, gen 10, 2011 20:36
Oggetto: [Qgis-developer] symlinks in GRASS plugins
A: "qgis-developer" <qgis-developer at lists.osgeo.org>, "Paolo Cavallini" <cavallini at faunalia.it>
W dniu 09.01.2011 11:16, Paolo Cavallini pisze:
> In the GRASS plugin there are tens of repeated icons. I would like to
> replace them with symlinks, to keep everything more tidy. In principle
> this should work:
> http://www.rekk.de/bloggy/2008/versioning-symlinks-with-subversion-on-linux/
> but in practice it does not:
> https://trac.osgeo.org/qgis/changeset/15006/trunk
> I replaced v.in.gns.?.* with links, but the module do not see them.
> I do not know if:
> - the method does not work (unlikely)
> - I did something wrong
> - the GRASS plugin requires the image, and does not accept a link.
Hi Paolo,
Maybe a file external instead? SVN >= 1.6 is needed. An example:
### CREATE THE FILE ###
  $ echo 'file1 content' > repo_wc/file_1.txt
  $ svn add repo_wc/file_1.txt
  A         repo_wc/file_1.txt
  $ svn ci repo_wc/file_1.txt -m 'adding file_1.txt to version control'
  Adding         repo_wc/file_1.txt
  Transmitting file data .
  Committed revision 1.
### LINK IT ###
  $ svn up repo_wc/
  At revision 1.
  $ svn propset svn:externals 'file_2.txt
file:///home/pok/repo/file_1.txt' repo_wc/
  property 'svn:externals' set on 'repo_wc'
  $ svn ci repo_wc/ -m 'file_2.txt is a copy of file_1.txt'
  Sending        repo_wc
  Committed revision 2.
  $ svn up repo_wc/
  Fetching external item into 'repo_wc/file_2.txt'
  E    repo_wc/file_2.txt
  Updated external to revision 2.
  Updated to revision 2.
### BOTH FILES ARE NOW THERE AND HAVE THE SAME CONTENT ###
  $ ls -l repo_wc/
  total 8
  -rw-r--r-- 1 pok pok 14 Jan 10 20:23 file_1.txt
  -rw-r--r-- 1 pok pok 14 Jan 10 20:24 file_2.txt
  $ cat repo_wc/*
  file1 content
  file1 content
Maciek
Maciej Sieczka
http://www.sieczka.org
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110111/0ad33c66/attachment.html
