[Qgis-developer] Re: Qgis Trunk r15027 - /qgis/core.so: undefined
symbol: _ZN19QgsComposerScaleBar16applyDefaultSizeEv
Noli Sicad
nsicad at gmail.com
Fri Jan 14 03:24:59 EST 2011
I am using Lucid Nightly build.
http://www.qgis.org/wiki/Download#Ubuntu
I am not compiling. I am using the Synaptic Package Manager.
However, in console / terminal is saying the right version.
noli at noli-laptop:~$ qgis --help
Quantum GIS - 1.7.0-Trunk 'Trunk' (15038M)
Quantum GIS (QGIS) is a viewer for spatial data sets, including
raster and vector data.
Usage: qgis [options] [FILES]
options:
[--snapshot filename] emit snapshot of loaded datasets to given file
[--width width] width of snapshot to emit
[--height height] height of snapshot to emit
[--lang language] use language for interface text
[--project projectfile] load the given QGIS project
[--extent xmin,ymin,xmax,ymax] set initial map extent
[--nologo] hide splash screen
[--noplugins] don't restore plugins on startup
[--optionspath path] use the given QSettings path
[--configpath path] use the given path for all user configuration
[--help] this text
FILES:
Files specified on the command line can include rasters,
vectors, and QGIS project files (.qgs):
1. Rasters - Supported formats include GeoTiff, DEM
and others supported by GDAL
2. Vectors - Supported formats include ESRI Shapefiles
and others supported by OGR and PostgreSQL layers using
the PostGIS extension
Who is responsible for this nightly build? Is it done automatically?
Thanks.
Noli
On 1/14/11, Marco Hugentobler <marco.hugentobler at sourcepole.ch> wrote:
>> The funny thing, it is reporting a very old QGIS 14993M and GDAL 1.6.3
> Could it be that you are linking to an old version of libqgis_core.so?
> Because
> QgsComposerScaleBar::applyDefaultSize was added after 14993, so a conflict
> between two library versions could be the reason.
> Regards,
> Marco
> Am Freitag, 14. Januar 2011, um 07.21:49 schrieb Noli Sicad:
>> Updated to 1.7. SVN r15038. Ubuntu 10.04 a few minutes ago.
>> I still got the same problem.
>> Couldn't load PyQGIS.
>> Python support will be disabled.
>> Traceback (most recent call last):
>> File "", line 1, in
>> ImportError: /usr/lib/python2.6/dist-packages/qgis/core.so: undefined
>> Python version:
>> 2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
>> [GCC 4.4.3]
>> QGIS version:
>> 1.7.0-Trunk 'Trunk', 14993M
>> I hope it will be fixed in the next version.
>> Noli
>> On 1/14/11, Noli Sicad <nsicad at gmail.com> wrote:
>> > Hi,
>> > I got this error,
>> > /qgis/core.so: undefined symbol:
>> > in Qgis Trunk r15027 Ubuntu 10.04.
>> > File "", line 1, in
>> > Python version:
>> > Noli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
