[Qgis-developer] Re: Qgis Trunk r15027 - /qgis/core.so: undefined
symbol: _ZN19QgsComposerScaleBar16applyDefaultSizeEv
Noli Sicad
nsicad at gmail.com
Sat Jan 15 02:48:43 EST 2011
Still this undefined symbol: _ZN19QgsComposerScaleBar16applyDefaultSizeEv is in
Quantum GIS - 1.7.0-Trunk 'Trunk' (15050M)
Anybody can fix this undefined symbol?
Couldn't load PyQGIS.
Python support will be disabled.
File "", line 1, in
ImportError: /usr/lib/python2.6/dist-packages/qgis/core.so: undefined
Thanks.
Noli
On 1/14/11, Noli Sicad <nsicad at gmail.com> wrote:
> I am using Lucid Nightly build.
> http://www.qgis.org/wiki/Download#Ubuntu
> I am not compiling. I am using the Synaptic Package Manager.
> However, in console / terminal is saying the right version.
> noli at noli-laptop:~$ qgis --help
> Quantum GIS - 1.7.0-Trunk 'Trunk' (15038M)
> Quantum GIS (QGIS) is a viewer for spatial data sets, including
> raster and vector data.
> Usage: qgis [options] [FILES]
> options:
> [--snapshot filename] emit snapshot of loaded datasets to given file
> [--width width] width of snapshot to emit
> [--height height] height of snapshot to emit
> [--lang language] use language for interface text
> [--project projectfile] load the given QGIS project
> [--extent xmin,ymin,xmax,ymax] set initial map extent
> [--nologo] hide splash screen
> [--noplugins] don't restore plugins on startup
> [--optionspath path] use the given QSettings path
> [--configpath path] use the given path for all user configuration
> [--help] this text
> FILES:
> Files specified on the command line can include rasters,
> vectors, and QGIS project files (.qgs):
> 1. Rasters - Supported formats include GeoTiff, DEM
> and others supported by GDAL
> 2. Vectors - Supported formats include ESRI Shapefiles
> and others supported by OGR and PostgreSQL layers using
> the PostGIS extension
> Who is responsible for this nightly build? Is it done automatically?
> Thanks.
> Noli
> On 1/14/11, Marco Hugentobler <marco.hugentobler at sourcepole.ch> wrote:
>>> The funny thing, it is reporting a very old QGIS 14993M and GDAL 1.6.3
>> Could it be that you are linking to an old version of libqgis_core.so?
>> Because
>> QgsComposerScaleBar::applyDefaultSize was added after 14993, so a
>> conflict
>> between two library versions could be the reason.
>> Regards,
>> Marco
>> Am Freitag, 14. Januar 2011, um 07.21:49 schrieb Noli Sicad:
>>> Updated to 1.7. SVN r15038. Ubuntu 10.04 a few minutes ago.
>>> I still got the same problem.
>>> File "", line 1, in
>>> Python version:
>>> 2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
>>> [GCC 4.4.3]
>>> QGIS version:
>>> 1.7.0-Trunk 'Trunk', 14993M
>>> I hope it will be fixed in the next version.
>>> Noli
>>> > Hi,
>>> > I got this error,
>>> > /qgis/core.so: undefined symbol:
>>> > in Qgis Trunk r15027 Ubuntu 10.04.
>>> > File "", line 1, in
>>> > Python version:
>>> > Noli
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Dr. Marco Hugentobler
>> Sourcepole - Linux & Open Source Solutions
>> Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
>> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
>> Technical Advisor QGIS Project Steering Committee
