[Qgis-developer] Python scrpt to join attributes from DBF -
ftools is very slow
Noli Sicad
nsicad at gmail.com
Sat Jan 15 23:22:49 EST 2011
Yes, I tried MMQGIS. It did not work. It read the column names but
not the data.
Ftools is more robust than mmqgis, I think. It is just slow.
I understand Ftools is in the process of being ported to C++ plugins.
Noli
On 1/16/11, Maurício de Paulo <mauricio.dev at gmail.com> wrote:
> I think I've seen a plugin called mm something that had a join tool in the
> repository.
> On Sun, Jan 16, 2011 at 12:36 AM, Noli Sicad <nsicad at gmail.com> wrote:
>> Hi,
>> I am trying to join attributes from DBF file to shapefile and I find
>> flools very slow to do this job.
>> Here is the facts
>> 1. DBF file is 44.8 Mb to be joined to shapefile
>> 2. flools is working but only creating 2 Mb per 30 minutes on dbf file.
>> 3. Qgis freezed by flools is still working.
>> At this rate, it will take me 22 hrs to get the final result.
>> Any python script or any script, solution to speed this job?
>> Do you think doing this job using spatialite will speed up completion
>> of this job?
>> Thanks.
>> Noli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Mauricio de Paulo
> Engenheiro Cartografo
> MapeandoOBrasil <http://mapeandoobrasil.blogspot.com>
