[Qgis-developer] Openlayers plugin python error
    Luiz Motta
    motta.luiz at gmail.com
    Wed Jan 19 12:46:26 EST 2011
Giovanni,
The message  error occurr in  MemoryLayerSaver's plugins.
Disable all plugins and work only OpenLayers's plugin.
Open the layer (ex.: shapefile with projection) and try
2011/1/19 Giovanni Manghi <giovanni.manghi at gmail.com>
> Hi,
> under Ubuntu linux (10.04) and qgis trunk I get the following when
> adding layers with the Openlayers plugin. The error is not critical as
> the layer is added in any case.
> An error has occured while executing Python code:
> Traceback (most recent call last):
>  File
> "/home/gio/.qgis/python/plugins/MemoryLayerSaver/MemoryLayerSaver.py",
> line 41, in connectProvider
>    if self.isSavedLayer(layer):
>  File
> line 90, in isSavedLayer
>    if not l.dataProvider():
> AttributeError: 'OpenlayersLayer' object has no attribute 'dataProvider'
> cheers
> -- Giovanni --
> Qgis-developer mailing list
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110119/9cf861ec/attachment.html
