[Qgis-developer] Openlayers plugin python error
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Jan 19 12:52:10 EST 2011
Sorry,
you are right, I didn't noticed that the error message was about another
plugin.
Nevertheless the note stays for the MemoryLayerSaver author.
cheers
-- Giovanni --
On Wed, 2011-01-19 at 15:46 -0200, Luiz Motta wrote:
> Giovanni,
> The message error occurr in MemoryLayerSaver's plugins.
> Disable all plugins and work only OpenLayers's plugin.
> Open the layer (ex.: shapefile with projection) and try
> 2011/1/19 Giovanni Manghi <giovanni.manghi at gmail.com>
> Hi,
> under Ubuntu linux (10.04) and qgis trunk I get the following
> when
> adding layers with the Openlayers plugin. The error is not
> critical as
> the layer is added in any case.
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File
> "/home/gio/.qgis/python/plugins/MemoryLayerSaver/MemoryLayerSaver.py",
> line 41, in connectProvider
> if self.isSavedLayer(layer):
> File
> line 90, in isSavedLayer
> if not l.dataProvider():
> AttributeError: 'OpenlayersLayer' object has no attribute
> 'dataProvider'
> cheers
> -- Giovanni --
> Qgis-developer mailing list
