[Qgis-developer] Bug in QGIS 1.7 raster? Changing transparency values set the 3 RGB bands to band 1?
benoit-3 at bc-consult.com
Fri Jan 21 16:15:31 EST 2011
Hi Devs,
Forget about my rumblings of yesterday (see below)
The
problem is worse:
- Open a three-band raster into QGIS. It is displayed
OK.
- Open the raster properties window and bang, the three bands (RGB)
are set to Band 1. Resulting in a grey coloured raster if user click
either Apply or OK.
Is that on purpose?
Regards,
Benoit
Original
message:
With QGIS 1.7 release r15056 on WinXP Pro.
I have a
three-band raster (geotiff) loaded and it displays all-right. Then
I
open the raster properties window, go to the transparency tab, slide
the transparency ruler and click Apply. The transparency is applied to
the
raster but the three bands (R,G,B) are all set to band 1 resulting
in a
black&white (grey) raster!
The same behaviour is observed when
I add a transparent pixel and click
Apply...
Can someone confirm
these behaviours?
Regards,
Benoit
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110121/86c6bbc9/attachment.html
