[Qgis-developer] Failing to build current trunk on Debian
Jürgen E. Fischer
jef at norbit.de
Fri Jan 28 06:11:49 EST 2011
Hi Ivan,
On Fri, 28. Jan 2011 at 11:42:24 +0100, Ivan Mincik wrote:
> Hi,
> building Debian Lenny package with current trunk is failing at the end on
Strange. The nightly build builds fine (both on i386 and amd64):
-- Installing: /tmp/buildd/qgis-1.7.0+svn15091~lenny1/debian/tmp/usr/lib/qgis/plugins/libogrconverterplugin.so
-- Installing: /tmp/buildd/qgis-1.7.0+svn15091~lenny1/debian/tmp/usr/lib/qgis/plugins/libdiagramoverlay.so
-- Installing: /tmp/buildd/qgis-1.7.0+svn15091~lenny1/debian/tmp/usr/lib/qgis/plugins/libevis.so
Looks like the diagramoverlay plugin doesn't get compiled in your build. Could
you put the complete log somewhere?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
