[Qgis-developer] Failing to build current trunk on Debian
Ivan Mincik ivan.mincik at gista.sk
Fri Jan 28 07:08:17 EST 2011
On 01/28/2011 12:11 PM, Jürgen E. Fischer wrote:
> Hi Ivan,
> On Fri, 28. Jan 2011 at 11:42:24 +0100, Ivan Mincik wrote:
>>     Hi,
>>     building Debian Lenny package with current trunk is failing at the end on
> Strange.  The nightly build builds fine (both on i386 and amd64):
> -- Installing: /tmp/buildd/qgis-1.7.0+svn15091~lenny1/debian/tmp/usr/lib/qgis/plugins/libogrconverterplugin.so
> -- Installing: /tmp/buildd/qgis-1.7.0+svn15091~lenny1/debian/tmp/usr/lib/qgis/plugins/libdiagramoverlay.so
> -- Installing: /tmp/buildd/qgis-1.7.0+svn15091~lenny1/debian/tmp/usr/lib/qgis/plugins/libevis.so
> Looks like the diagramoverlay plugin doesn't get compiled in your build.  Could
> you put the complete log somewhere?
It is here [1]. Log is from my PBuilder environment, which was building
fine until now.
Thanks
[1] - http://gista.sk/home/ivo/dl/qgis_1.7.0-trunk.build
Ivan Mincik, Gista s.r.o.
