[Qgis-developer] Failing to build current trunk on Debian
Jürgen E. Fischer
jef at norbit.de
Fri Jan 28 07:35:40 EST 2011
Hi Ivan,
On Fri, 28. Jan 2011 at 13:08:17 +0100, Ivan Mincik wrote:
> On 01/28/2011 12:11 PM, Jürgen E. Fischer wrote:
>> Looks like the diagramoverlay plugin doesn't get compiled in your build. Could
>> you put the complete log somewhere?
> It is here [1]. Log is from my PBuilder environment, which was building
> fine until now.
AFAICS there are no "real" errors before and the only difference is that you
are building with a new GRASS and GDAL version - but I don't see why that
should affect the diagramoverlay plugin.
Do you run out of disk space by any chance?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
