[Qgis-developer] Failing to build current trunk on Debian
Ivan Mincik ivan.mincik at gista.sk
Fri Jan 28 09:08:45 EST 2011
On 01/28/2011 01:35 PM, Jürgen E. Fischer wrote:
> Hi Ivan,
> On Fri, 28. Jan 2011 at 13:08:17 +0100, Ivan Mincik wrote:
>> On 01/28/2011 12:11 PM, Jürgen E. Fischer wrote:
>>> Looks like the diagramoverlay plugin doesn't get compiled in your build.  Could
>>> you put the complete log somewhere?
>> It is here [1]. Log is from my PBuilder environment, which was building
>> fine until now.
> AFAICS there are no "real" errors before and the only difference is that you
> are building with a new GRASS and GDAL version - but I don't see why that
> should affect the diagramoverlay plugin.
> Do you run out of disk space by any chance?
No, I have checked that. I will try to build again and look closely for
problems on my side.
Ivan Mincik, Gista s.r.o.
