[Qgis-developer] Failing to build current trunk on Debian
Ivan Mincik ivan.mincik at gista.sk
Fri Jan 28 09:53:41 EST 2011
On 01/28/2011 01:35 PM, Jürgen E. Fischer wrote:
> Hi Ivan,
> On Fri, 28. Jan 2011 at 13:08:17 +0100, Ivan Mincik wrote:
>> On 01/28/2011 12:11 PM, Jürgen E. Fischer wrote:
>>> Looks like the diagramoverlay plugin doesn't get compiled in your build.  Could
>>> you put the complete log somewhere?
>> It is here [1]. Log is from my PBuilder environment, which was building
>> fine until now.
> AFAICS there are no "real" errors before and the only difference is that you
> are building with a new GRASS and GDAL version - but I don't see why that
> should affect the diagramoverlay plugin.
> Do you run out of disk space by any chance?
Jürgen, I have found the problem on my side (quite tricky problem with
XEN VM :)).
Thanks and sorry for teasing You.
Ivan Mincik, Gista s.r.o.
