[Qgis-developer] Re: [Qgis-user] Announcing RoadGraph plugin
Paolo Cavallini cavallini at faunalia.it
Sat Jan 29 05:52:30 EST 2011
Il giorno ven, 28/01/2011 alle 08.13 +0300, Sergey Yakushev ha scritto:
> Hi Tim.
> 1. You need to configure the plugin ("Plugins => road graph => settings")
> 2. "Plugins => road graph => show roads direction" for highlight roads direction. I use this for testing settings.
> 3. Road graph plugin have problem with tie point to graph. Try for very short path and big scale (e.g. 1:1).
Just tested the plugin. I got a (unrelated) std::bad alloc popup at
startup, anc when pressing Calculate on a very simple graph I got:
***************** deactivate circulararctool
***************** deactivate modifycirculararctool
Segmentation fault
from kern.log:
qgis.bin[14187]: segfault at 0 ip 00007f39c2a83a41 sp 00007fff465d9830
error 4 in libroadgraphplugin.so[7f39c2a69000+30000]
Tried twice, same result:
qgis.bin[2934]: segfault at 0 ip 00007ffd9270ca41 sp 00007fff967861d0
error 4 in libroadgraphplugin.so[7ffd926f2000+30000]
All the best.
http://www.faunalia.it/pc
