[Qgis-developer] Re: [Qgis-user] Announcing RoadGraph
	plugin
    Tim Sutton
    lists at linfiniti.com
    Sat Jan 29 14:02:04 EST 2011
Hi
On Sat, Jan 29, 2011 at 12:52 PM, Paolo Cavallini <cavallini at faunalia.it> wrote:
> Il giorno ven, 28/01/2011 alle 08.13 +0300, Sergey Yakushev ha scritto:
>> Hi Tim.
>> 1. You need to configure the plugin ("Plugins => road graph => settings")
>> 2. "Plugins => road graph => show roads direction" for highlight roads direction. I use this for testing settings.
>> 3. Road graph plugin have problem with tie point to graph. Try for very short path and big scale (e.g. 1:1).
Ok thanks I got it to work after much trial and error to get the start
point to overlap with my road. Snapping in selection of start and end
point would definately prove useful.
Sergey thank you for your contribution - its going to be  a nice new
feature in QGIS!
Regards
Tim
> Just tested the plugin. I got a (unrelated) std::bad alloc popup at
> startup, anc when pressing Calculate on a very simple graph I got:
> ***************** deactivate circulararctool
> ***************** deactivate modifycirculararctool
> Segmentation fault
> from kern.log:
> qgis.bin[14187]: segfault at 0 ip 00007f39c2a83a41 sp 00007fff465d9830
> error 4 in libroadgraphplugin.so[7f39c2a69000+30000]
> Tried twice, same result:
> qgis.bin[2934]: segfault at 0 ip 00007ffd9270ca41 sp 00007fff967861d0
> error 4 in libroadgraphplugin.so[7ffd926f2000+30000]
> All the best.
> http://www.faunalia.it/pc
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
