[Qgis-developer] QGIS Processing Framework
MALIK Julien julien.malik at c-s.fr
Fri Jul 8 01:46:10 EDT 2011
Hello Camilo,
Some feedback about your todo list :
- constraints and validator is low priority to me : it can be handled
by the underlying implementation for now
- user level is low priority to me as it will probably be easy to add
this feature later when the big things will be in shape
- interactive parameters : higher priority to me. Having a way for the
implementation to tell the GUI "update every widgets". Maybe I already
have a way to do that (?)
A few things you don't mention :
- running the processing modules programmatically
- progress reporting
- logging
- multiple values parameter type (at least to provide a "multiple
input layers" parameter type)
- parameter groups (what happen currently with the SAGA "nodes" ?)
I agree with your analysis : being able to access the QGis layers for
the input/output is now the most important thing to focus on.
What precisely is blocking you on this topic ?
I saw some recent updates adding a combobox with the layers but did
not test it yet. The implementations could handle the conversion into
their own internal data structure from the MapLayer objects.
I know at least that on the OTB side, a first step will be getting a
gdal/ogr compatible dataset name and pass them as input files to the
implementation.
As I can remember, SAGA has a "gdal/ogr" importer module for inputs,
and the output should be simple also as the saga file format is
supported by gdal.
Regards,
Julien
Quoting Camilo Polymeris <cpolymeris at gmail.com>:
> Hello everyone,
> the end of GSoC's first term is nearing and while I think we have made
> a significant progress, many things are still pending. I have tried to
> identify a few and compile a short list[1], to try to keep focused
> during the next few weeks.
> I'll try to create a proper timeline with (some of) those items &
> would appreciate your comments. Anything missing? Some things more
> urgent than others?
> Of course, most of the work will revolve around the first item: Data
> exchange. Still no clarity on how to handle that.
> Regards,
> Camilo
This message was sent using IMP, the Internet Messaging Program.
