Fw: [Qgis-developer] QGIS-MapServer 1.7 GetFeatureInfo problem
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Tue Jul 12 03:36:23 EDT 2011
Hi Pedro
I've tried your example with the packages, the 1.7 branch and the developer
version. The featureinfo worked for me with the 1.7 branch and the dev
version, but not with the packages.
I didn't try the 1.7 release sources yet. Maybe it's something that was
changed and backported to 1.7 (though I don't remember any changes there).
Regards,
Marco
Am Montag, 11. Juli 2011, 21.33:42 schrieb Pedro Venâncio:
> Just to be sure, I did the downgrade to 1.6 (ubuntugis-stable repository)
> and everything is running smoothly again.
> So, it appears to be something with the version 1.7.
> Nobody can reproduce this behavior?
> Thanks again!
> Pedro
> ----- Forwarded Message -----
> From: Pedro Venâncio
> To: Marco Hugentobler
> Hello Marco,
> >>Could you provide a sample project and dataset for us to test?
> Sending two shapefiles that I'm using and the project (.qgs) I am trying to
> publish.
> Everything works fine, except Identify tool who does not act as declared in
> the GetCapabilities (<Layer queryable="1">).
> >>Possible is also a library conflict if you have several qgis libs on your
> >>system.
> I do not know if this could be the problem, because one of the machines I'm
> running has a Ubuntu clean installation.
> Thanks for your support!
> Best regards,
> Pedro
> ----- Original Message -----
> From: Marco Hugentobler
> Cc:
> Sent: Monday, July 11, 2011 4:53 PM
> Subject: Re: [Qgis-developer] QGIS-MapServer 1.7 GetFeatureInfo problem
> Hi Pedro
> > In addition, this same configuration worked without problems before
> > upgrading to version 1.7.
> system.
> Regards,
> Marco
> Am Montag, 11. Juli 2011, 17.44:39 schrieb Pedro Venâncio:
> > Hello Andreas,
> > Yes, I think this aspect is not the problem, everything is in EPSG:20790
> > (QGIS project, all layers and the project - and wms layers - as client).
> > Thanks,
> > Pedro
> > From: Andreas Neumann
> > Hi Pedro,
> > Is the CRS (projection, coordinate reference system) set up correctly in
> > the WMS and in the WMS client? Is the QGIS project set up correctly with
> > the CRS?
> > Andreas
> > On Mon, 11 Jul 2011 07:19:49 -0700 (PDT), Pedro Venâncio wrote:
> > > Hello everyone,
> > > I have a problem in QGIS-MapServer 1.7. The result of Identify is
> > > blank on QGIS 1.7.
> > > I found this problem on a clean Ubuntu install of QGIS and
> > > QGIS-MapServer 1.7. Since I had another machine with QGIS and
> > > QGIS-MapServer 1.6 running smoothly, I did the upgrade to 1.7 on this
> > > machine (also Ubuntu) and the same application crashed the Identify
> > > feature after the upgrade.
> > > The GetCapabilities continues to show the layers as identifiable
> > > (queryable = "1"), however QGIS displays the results in white (see
> > > picture). This happens with both point, polyline and polygon features.
> > > Can anyone confirm this?
> > > Thank you!
> > > Pedro Venâncio
> > Andreas Neumann
> > Böschacherstrasse 10A
> > 8624 Grüt (Gossau ZH)
> > Switzerland
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
