[Qgis-developer] Print Composer crashing
Ramon Andinach
custard at westnet.com.au
Wed Jul 20 19:16:39 EDT 2011
Hi Joze,
I'm presuming you wanted this back on the list.
Firstly, I can get this without using ECW or large page sizes or high resolutions.
Secondly, you've got two different problems there.
Large page sizes is a known bug - http://hub.qgis.org/issues/3687
And ECW support for ubuntu was described quite nicely just a few days back on the user list:
http://lists.osgeo.org/pipermail/qgis-user/2011-July/012732.html
additionally, try here: http://trac.osgeo.org/gdal/wiki/ECW
Hope some of that's a help.
-ramon.
On 21/07/2011, at 03:04 , Jože Detečnik wrote:
> Hello,
> I have the same simptoms. Seems there is a memory leak problem on windows no
> matter versions. For formats A1- decrease dpi to 100 or less dpi help. I'm
> testing ubuntu version but there is no ECW support or I don't know how to
> setup.
> Joze
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org
> [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Ramon Andinach
> Sent: Wednesday, July 20, 2011 5:41 PM
> To: qgis-dev
> Subject: [Qgis-developer] Print Composer crashing
> Hi all,
> I'm not sure if this is related to the Print Composer problems being
> discussed on the user list. Thus far I haven't had the white stripe.
> I've been having problems where the Print Composer either
> a) causes QGIS to crash out-right, or
> b) appears to hang then gives a dialogue saying "bad allocation", which then
> breaks that composer session, and usually crashes QGIS shortly afterwards.
> To replicate, I provide a small .zip file
> http://www.members.westnet.com.au/ramon_et_al/PrintComposerError.zip
> 1. Unzip, and open the project.
> 2. Using the print manager, open one of the compsers.
> 3. Export to image. If the geology (filled polygon) layer is in the
> composer, the the composer will not complete.
> I'm having similar problems with printing directly to printer, and to PDF.
> I've tried this project out on:
> Win7 64-bit using standalone 1.7 install
> Win7 64-bit using osgeo 1.7 install (there are debug files from this system
> provided)
> Win7 64-bit using osgeo 1.8 install
> WinXP 32-bit using standalone 1.7 install
> I'm fairly sure that its related to something specific in certain vector
> files. For instance the polygon file provided is an excerpt of one that is
> giving me problems.
> Would it be possible for someone to confirm that I'm not hallucinating?
> If there is a problem, is it likely to be that there is something about that
> file that causes problems? If so, does anyone have any suggestions? I've
> pointed the f-tools geometry validation tool at it and nothing came up.
> -ramon._______________________________________________
> Qgis-developer mailing list
