[Qgis-developer] Re: build without spatialite
Marco Bernasocchi marco at bernawebdesign.ch
Fri Jul 22 20:03:58 EDT 2011
Found the solution (thx tim), just set
-DSQLITE3_INCLUDE_DIR=$INSTALL_DIR/include \
-DSQLITE3_LIBRARY=$INSTALL_DIR/lib/libsqlite3.so \
-DWITH_INTERNAL_SPATIALITE=OFF \
-DWITH_SPATIALITE=OFF
and it works
ciao
On 07/22/2011 10:05 PM, Marco Bernasocchi wrote:
> Hi all, I'm trzing to build qgis with no spatialite to simplify the
> port to android. For I get to the linking of qgis core and then have a
> linker error. so I decided to try to symply disable spatialite bz
> setting -DWITH_INTERNAL_SPATIALITE=OFF -DWITH_SPATIALITE=OFF but I get
> this error, any idea?
> CMake Error at CMakeLists.txt:146 (MESSAGE):
>   sqlite3 dependency was not found (try compiling with internal
> spatialite)!
> -- Pedantic compiler settings enabled
> -- Debug output enabled
> -- txt2tags not found - disabled
> CMake Error: The following variables are used in this project, but
> they are set to NOTFOUND.
> Please set them or make sure they are set and tested correctly in the
> CMake files:
> SQLITE3_INCLUDE_DIR
>    used as include directory in directory /home/marco/dev/qgis/src/core
>    used as include directory in directory /home/marco/dev/qgis/src/gui
> /home/marco/dev/qgis/src/providers/osm
> /home/marco/dev/qgis/src/helpviewer
> /home/marco/dev/qgis/src/browser
> SQLITE3_LIBRARY
>     linked by target "qgis_core" in directory
>     linked by target "qgis_help" in directory
>     linked by target "qbrowser" in directory
> -- Configuring incomplete, errors occurred!
> ciao Marco
