[Qgis-developer] Re: SDA4PP Kernel density troubleshooting
Giovanni Manghi
giovanni.manghi at gmail.com
Wed Jul 27 17:32:18 EDT 2011
On Wed, 2011-07-27 at 14:23 -0700, DartVader wrote:
> Unfortunately, I've played the video after I posted a reply. Anyway, now I
> know what path have you been talking about. Does the whole process mean,
> that after adding it to the path, it will load every time I start windows,
> thus it'll run in backround?
no, it means that the (R) binaries will be available system wide -> can
be called from another application
> And by the way, is the Home Range plugin a competitor to SDA4PP? Does it the
> same thing, with same or better results?
No, it is just another plugin that uses R -> the process to have it
working is the same as SDA4PP.
