[Qgis-developer] Re: SDA4PP Kernel density troubleshooting
DartVader
compp at seznam.cz
Sat Jul 30 06:26:36 EDT 2011
Hi, thanks again for your quick reply and at the same time I appologize for
my late answer.
I went through your video tutorial many times to be sure, that I didnt do
anything wrong and doing so, after start of a home_range plugin and any type
of calculation I bumped to an *error msg*:
R error (please consult its documentation) is:
Error in function (x, method = c("mcp", "href", "lscv", "hadj", "clusthr",
This procedure requires adehabitat to be installed
I don't get it, really. After all I upgraded to a gqis 1.7.0 and R 2.11.1
and did everything like shown in the video. And eventhough I have Windows
XP, I copied the R libraries into a different location (also by that time,
replaced the original path to the R in the windows PATH by the new one. It
must be also said, the I tried to run home_range with the original path and
after the change, and still with same results.)
And also the adehabiat, I installed it like for three times, although I
didn't have to. It was succesfully installed the first time. So, the
home_range plugin doesn't work for me now.
But not to be only negative, I thing I managed to find out the center of the
problem from my first post. If you remember, I couldn't run the SDA4PP
without error msg: "blah blah....don't use ascii letters...blah blah ". So I
thing, the problem was not only in a coding of the file (.gpx or .shp), well
it might play its role too, but mainly because those non ascii letter must
not be in the path, where the plugin gets the data from.
So in my case, in the time of the error msg, it was like this: "C:\Documents
and Settings\DartVader\Plocha\EVL Ch_luh\*zkouška*\test SDA4PP\gh.shp"
As you can see, there is "zkouška" with non ascii letter "š". After renaming
it to anything else without diacriticals, the plugin works correctly.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SDA4PP-Kernel-density-troubleshooting-tp6621793p6635974.html
Sent from the qgis-developer mailing list archive at Nabble.com.
