[Qgis-developer] Virtual columns in QGIS, was: Re: [Qgis-user]
object labels
kimaidou
kimaidou at gmail.com
Thu Jul 28 05:45:39 EDT 2011
Hi
Since I have not tested your patch yet, it is hard to comment. The
functionnalities I am thinking of for labelling purpose are :
* be able to add uppercase to the first letters of words
* add a line break after the first space after X letters (such as Mapserver
does with WRAP and MAXLENGTH ( http://mapserver.org/mapfile/label.html )
* Concatenate one or more columns with expresssions, such as : colA || '('
|| colB || ')' (here I am using the postgresql || syntaxe )
kimaidou
2011/7/28 Nathan Woodrow <madmanwoo at gmail.com>
> +1 from me too. A virtual column would be a very handy feature however you
> must be able to add one to read only datasets eg MI Tab otherwise their is
> no real advantage. The expression labelling I'm working on works with read
> only datasets. I think the expression based labelling and the virtual
> column thing could exist together quite well the former being a short cut in
> the labeling gui for the latter.
> Check out http://hub.qgis.org/issues/3488 and
> https://github.com/NathanW2/Quantum-GIS/tree/expression-labels for the
> status of my patch. I have been away for a couple of weeks but I will be
> getting back into over the next couple of weeks.
> Anyone else got any other thoughts?
> - Nathan
> On Thu, Jul 28, 2011 at 6:49 PM, kimaidou <kimaidou at gmail.com> wrote:
>> Hi,
>> +1 for Mayeul Nathan. This "virtual column" would be a very handy tool !
>> E.G for labelling
>> kimaidou
>> 2011/7/28 Andreas Neumann <a.neumann at carto.net>
>>> Hi Nathan,
>>> Good to hear that you are working on this.
>>> I just wonder if it wouldn't make sense to have a general purpose
>>> "virtual column" that could be introduced in QGIS. This would be useful for:
>>> * labeling
>>> * map tips/QGIS server tooltip display
>>> * symbology
>>> * plugins
>>> * others?
>>> It would be convenient to use the field calculator, but instead of just
>>> writing out to a physically existing column it would create a new virtual
>>> column, just like a virtual column in a database view.
>>> Otherwise one would have to develop the same functionality several times
>>> - for labeling, for tooltips, etc.
>>> Do you think it would be feasible to implement this on a lower level in
>>> QGIS so that users could transparently work with virtual columns wherever
>>> they want?
>>> Andreas
>>> On Thu, 28 Jul 2011 16:09:56 +1000, Nathan Woodrow wrote:
>>>> My upcoming patch that adds expression based labels will be able
>>>> to achieve this once it's completed; I'm just cleaning up the UI
>>>> and testing everything then I will get the guys to merge it in.
>>>> Until then you will need to create a new column.
>>>> - Nathan
>>>> On Wed, Jul 27, 2011 at 9:15 PM, Torsten Lange wrote:
>>>> Ok, thank you, Andreas!
>>>>> Torsten
>>>>> Am Mittwoch 27 Juli 2011, 11:00:01 schrieb Andreas Neumann:
>>>>> Hi,
>>>>> > Currently, you have to create a new column. I usually create a
>>>>> view in
>>>>> > Postgis for this purpose.
>>>>> > It is in on the wishlist that one can create a "virtual" column
>>>>> - not
>>>>> > only for labeling, but also for map tips and perhaps
>>>>> symbolization.
>>>>> > Until then you have to do it yourself.
>>>>> > Andreas
>>>>> > On Tue, 26 Jul 2011 22:51:34 +0200, Torsten Lange wrote:
>>>>> > > Hi,
>>>>> > > Is there a way just to print - lets say - the first four
>>>>> letters of a
>>>>> > > objects
>>>>> > > name? Or must I create a new row for that?
>>>>> > > Thank you, Torsten
>>>>> > > ______________________________**_________________
>>>>> > > Qgis-user mailing list
>>>>> > > Qgis-user at lists.osgeo.org [1]
>>>>> > > http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>[2]
>>>>> Qgis-user at lists.osgeo.org [3]
>>>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>[4]
>>>> Links:
>>>> [1] mailto:Qgis-user at lists.osgeo.**org <Qgis-user at lists.osgeo.org>
>>>> [2] http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>> [3] mailto:Qgis-user at lists.osgeo.**org <Qgis-user at lists.osgeo.org>
>>>> [4] http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
>>>> [5] mailto:tlange at gwdg.de
>>> Andreas Neumann
>>> Böschacherstrasse 10A
>>> 8624 Grüt (Gossau ZH)
>>> Switzerland
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110728/75d10c02/attachment.html
