[Qgis-developer] cmake cleanup to test (all platforms)
Tim Sutton
lists at linfiniti.com
Fri Jun 3 16:01:44 EDT 2011
Hi William
I tested on ubuntu natty 64 bit and all seemed to build fine. I tested
both checking out your master branch and then building in my existing
build-master build dir (worked fine), and by creating a new build dir
and building everything from scratch and with all options enabled. All
seems to work fine. I can test on windows next week when I get back to
the office with my vmware setup if you like.
RE release branch, yeah its probaby a little last minute to add it there.
Regards
Tim
On Fri, Jun 3, 2011 at 5:39 AM, William Kyngesburye
<woklist at kyngchaos.com> wrote:
> Indeed, I had to change qgispython back to a library - the runtime loading uses QLibrary, which looks for a dylib and would need an explicit path to find a framework, too much hassle.
> On Jun 2, 2011, at 9:11 PM, William Kyngesburye wrote:
>> Ah, the bits in the code that I haven't gotten to yet in my framework-ization - this is looking for the library still. Maybe those I should leave qgispython as a library, since it's not public.
>> But, shouldn't affect other platforms...
>> On Jun 2, 2011, at 8:30 PM, Tom Elwertowski wrote:
>>> Hi William,
>>> It built ok for me using OS X 10.5.8 but there seems to be a path problem loading Python:
>>> Debug: /Users/tce/developer/qgis/kyngchaos/Quantum-GIS/src/app/qgisapp.cpp: 4591: (loadPythonSupport) Couldn't load Python support library: Cannot load library /Users/tce/developer/qgis/kyngchaos/build473/QGIS.app/Contents/MacOS/lib/qgispython:
>>> Warning: Couldn't load Python support library: Cannot load library /Users/tce/developer/qgis/kyngchaos/build473/QGIS.app/Contents/MacOS/lib/qgispython: (dlopen(/Users/tce/developer/qgis/kyngchaos/build473/QGIS.app/Contents/MacOS/lib/libqgispython.dylib, 10): image not found)
>>> Tom
>>>> I've been working on some build stuff for OS X which includes general changes and cleanup in the cmake configuration.
>>>> It's in my master fork on github and I'd like others to check it out to make sure I didn't mess up anything:
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "History is an illusion caused by the passage of time, and time is an illusion caused by the passage of history."
> - Hitchhiker's Guide to the Galaxy
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
