[Qgis-developer] Re: dealing with "long" primary keys
wambacher
pille3 at hotmail.com
Mon Jun 6 08:21:24 EDT 2011
Ivan Mincik-2 wrote:
> Maybe somebody can briefly explain, what kind of technical problem there
> is. There is discussion about it every half a year and still I am not
> sure what is going on.
hi, let's go:
\d nodes
Tabelle »public.nodes«
Spalte | Typ | Attribute
id | bigint | not null
version | integer | not null
user_id | integer | not null
tstamp | timestamp without time zone | not null
changeset_id | bigint | not null
tags | hstore |
geom | geometry |
Indexe:
"pk_nodes" PRIMARY KEY, btree (id)
"idx_nodes_geom" gist (geom) CLUSTER
Check-Constraints:
"enforce_dims_geom" CHECK (st_ndims(geom) = 2)
"enforce_geotype_geom" CHECK (geometrytype(geom) = 'POINT'::text OR geom
IS NULL)
"enforce_srid_geom" CHECK (st_srid(geom) = 4326)
gis=# select max(id) from nodes;
max
1314039345
bigint = int*8/64bit, id is primary key getting bigger and bigger every
minute.
Add new layer:
http://wnordmann.homeunix.com/images/stories/osm/forum/screenshot-postgis-tabellen%20hinzufgen.png
and then
http://wnordmann.homeunix.com/images/stories/osm/forum/screenshot-kann%20die%20schlsselspalte%20nicht%20finden.png
can be tested in about 60 seconds. just create a table with pk type bigint
and try.
creating oid's wont't help as those are even bigger. OSM ist a really BIG
database!
that's all.
Regards
walter
btw: max(id) is now 1314048177 (20 minutes later)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/dealing-with-long-primary-keys-tp6440007p6444870.html
Sent from the qgis-developer mailing list archive at Nabble.com.
