[Qgis-developer] Preparing for the release announcement - plugin manager site
Alex Mandel tech_dev at wildintellect.com
Mon Jun 13 16:24:10 EDT 2011
Yes, please move your plugin over.
No need to delete it off the current site, at least not at this time.
Eventually that site will get turned off once the all the plugins are
moved and QGIS ships with the correct url to the new site.
Thanks,
Alex
On 06/13/2011 10:57 AM, Chris Crook wrote:
> Just wondering how the new plugins repository relates to the existing user contributed plugins repo.
> Should we move plugins to the new one, and if so should we delete them from the existing repository, or is it fine to have two versions of the same plugin?
> Cheers
> Chris
> _______________________________________
> From: Tim Sutton [lists at linfiniti.com]
> Sent: 13 June 2011 09:23
> To: qgis-developer
> Subject: [Qgis-developer] Preparing for the release announcement
> Hi All
> - Alessandro's new plugin manager site http://plugins.qgis.org
> If you have time, could you take a moment to test these sites by:
> - Upload any plugins you want to share to the http://plugins.qgis.org
> ______________________________________________________________________________________________________
> This message contains information, which is confidential and may be subject to legal privilege.
> If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
> If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
> LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
> Thank you.
> Qgis-developer mailing list
