[Qgis-developer] Preparing for the release announcement - plugin
manager site
Alessandro Pasotti
apasotti at gmail.com
Tue Jun 14 17:29:39 EDT 2011
2011/6/14 Chris Crook <ccrook at linz.govt.nz>
> Hi
> The repository looks good, but I couldn't upload the plugin - it failed
> with the message
> "File upload must be a valid QGIS Python plugin compressed archive.
> Cannot find valid metadata in VectorFieldRenderer/__init__.py"
> I suspect that this is because my __init__.py is structured as
> from Plugin import Plugin
> def name():
> return Plugin.LongName
> rather than just being specified as
> def name():
> return "VectorFieldRenderer"
Yes, this is probably the reason.
For security reasons there is no "eval" on the python code, a simple regexp
is used instead to extract the strings from the __init__ file.
> Is there a document which describes how a plugin needs to be coded to be
> uploadable to the repository?
This is one of the docs:
http://www.qgis.org/wiki/Writing_Python_Plugins#__init__.py
while developing the new repo, some variations were introduced, like the
icon (IIRC this has been discussed on the list).
> Also some while ago I proposed a convention of putting plugin documentation
> in an index.html file in the plugin directory (which is now supported by the
> showPluginHelp function in utils.py). I wonder if it would be good provide
> access to this from the plugin repository (ie make it available for viewing
> if it is included in the zip file).
I can't comment on this, I wasn't aware of this functionality.
You can file a feature request if you like.
> Also I'm wondering how to specify plugin tags?
Tags were introduced in Lisbon, at this time, they are only editable through
the plugin web interface, there is currently no way to put them in the
__init__ and have them automatically imported in the repo.
Thanks for your feedback.
Alessandro Pasotti
w3: www.itopen.it
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110614/28e0964c/attachment.html
