[Qgis-developer] Integrating OSSIM with QGIS
Tim Sutton
lists at linfiniti.com
Tue Jun 21 04:36:04 EDT 2011
Hi
On Tue, Jun 21, 2011 at 7:58 AM, Alexander Bruy
<alexander.bruy at gmail.com> wrote:
> Hi,
> 2011/6/20 Mingjie Su <Su.Ming at geoeye.com>:
>> 1) Since QGIS is hard coded to use the GDAL provider, we added the QgisAppSettings class to load the global settings (which is a plain text file with key/value pair) to select provider.
> maybe I miss something in discussion but is this new
> class (QgisAppSettings) is neccessary and why not use
> QSettings for this? There is a qgsoptions.h/cpp files to
> read and write QGIS setting
You are probably correct though its hard to discuss it without seeing
the code yet.
Regards
Tim
> Alexander Bruy
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
