[Qgis-developer] Integrating OSSIM with QGIS
Mingjie Su
Su.Ming at geoeye.com
Tue Jun 21 12:10:43 EDT 2011
We are using QSetting within the QgisAppSettings class. I will take a look to see if we can use qgsoptions.
Thanks,
Ming
-----Original Message-----
From: Alexander Bruy [mailto:alexander.bruy at gmail.com]
Sent: Tuesday, June 21, 2011 1:59 AM
To: Mingjie Su
Cc: Tim Sutton; qgis-developer at lists.osgeo.org; Peter Borissow; qgis-ossim at lists.sourceforge.net; Harsh Govind
Subject: Re: [Qgis-developer] Integrating OSSIM with QGIS
2011/6/20 Mingjie Su <Su.Ming at geoeye.com>:
> 1) Since QGIS is hard coded to use the GDAL provider, we added the QgisAppSettings class to load the global settings (which is a plain text file with key/value pair) to select provider.
maybe I miss something in discussion but is this new
class (QgisAppSettings) is neccessary and why not use
QSettings for this? There is a qgsoptions.h/cpp files to
read and write QGIS setting
Alexander Bruy
