[Qgis-developer] Printing 25k raster maps
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Jun 22 11:38:13 EDT 2011
Hi Rob
Just tested here and I can print my 1:25k maps here (geotiff though).
Do you have the possibility to make an example available (or send it to me
privately)? Please open a bug ticket with exact description of steps (e.g. if
you print to printer, export as pdf, export as image, operating system used).
Regards,
Marco
Am Mittwoch, 22. Juni 2011, 17.29:30 schrieb uk52rob:
> Hi All,
> Since changing to v1.7 Wroclaw, I can no longer print 1:25k raster mapping
> data.
> The data I have is currently in PNG format, and worked fine in v1.6
> Copiapo. It displays fine in the QGIS main window, but will not display in
> the print composer or actually print onto a page.
> I have tried re-downloading the raster file, re-importing it, starting a
> new project with it, re-installing QGIS, and even trying it on another PC,
> but all have the same problem.
> Has anyone else come across this? I desperately need a solution, otherwise
> i'm going to have to go back to v1.6, which is a real shame.
> Thanks,
> Rob
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstr. 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
