[Qgis-developer] QGIS Processing Framework
Paolo Cavallini
cavallini at faunalia.it
Tue Jun 28 04:36:01 EDT 2011
Il giorno mar, 28/06/2011 alle 03.09 -0400, Camilo Polymeris ha
scritto:
> On Mon, Jun 27, 2011 at 3:59 PM, Camilo Polymeris <cpolymeris at gmail.com> wrote:
> > Given that there are no objections & I have studied the traits docs
> > without finding any reason against it, I'll start migration of the
> > framework.
> Having trouble with that.. QGIS segfaults when I try to load any of
> the modules in enthought.traits, e.g.:
> import enthought.traits.api
> When running the import through pdb it seems to hang. Can someone
> please confirm?
> Thanks,
> Camilo
Confirmed, it crashes with
Loaded symbols
for /usr/lib/python2.7/dist-packages/enthought/traits/ctraits.so
Reading symbols
from /usr/lib/python2.7/dist-packages/enthought/traits/protocols/_speedups.so...(no debugging symbols found)...done.
Loaded symbols
for /usr/lib/python2.7/dist-packages/enthought/traits/protocols/_speedups.so
Core was generated by `/usr/bin/qgis.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0x00007f3bf98764c8 in ?? ()
traits from official deb package.
All the best.
Paolo Cavallini: http://www.faunalia.it/pc
