[Ubuntu] Re: [Qgis-user] Re: [Qgis-developer] qgis-saga-python
bindings in ubuntu
Camilo Polymeris
cpolymeris at gmail.com
Tue Jun 28 23:33:52 EDT 2011
The saga-qgis interface is pretty much non-functional yet. Could you specify
which problems you have encountered?
Are you using the faunalia version?
Camilo
El jun 28, 2011 12:35 p.m., "Agustin Lobo" <alobolistas at gmail.com> escribió:
> Johan,
> Problem solved by adding your repository:
> deb http://ppa.launchpad.net/johanvdw/sagacvs/ubuntu lucid main
> deb-src http://ppa.launchpad.net/johanvdw/sagacvs/ubuntu lucid main
> Unfortunately, this does not entirely solve the problem of the saga
> plugin in QGIS, but this is
> another story.
> Thanks!
> Agus
> 2011/6/28 Agustin Lobo <alobolistas at gmail.com>:
>> Johan,
>> Do not find python-saga in
>> https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
>> Instead, I find now 2.0.7+dfsg-0.5~lucid , but synaptic still finds
2.05 only
>> Thanks for taking care of ubuntu saga binaries.
>> Agus
>> 2011/6/28 Johan Van de Wauw <johan.vandewauw at gmail.com>:
>>> On Thu, Jun 23, 2011 at 11:10 AM, Agustin Lobo <alobolistas at gmail.com>
>>> wrote:
>>>> Is it possible to install the python bindings for a saga installation
>>>> from binaries friom ubuntugis-unstable?
>>> I'm currently busy uploading the new versions. After uploading it will
take
>>> approximately one hour to compile.
>>> Once this is done the package you are looking for is called: python-saga
>>>> Also, while I do have the ubuntugis-unstable repository in the
>>>> synaptic list, synaptic finds saga 2.05+dfsg-0.1~lucid
>>>> while https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
>>>> lists saga 2.0.6+dfsg-0~lucid. Why?
>>> Because it was uploaded but (for some reason) did not compile. Not your
>>> fault.
>>>> Thanks
>>>> Agus
>>>> ---------- Forwarded message ----------
>>>> From: MALIK Julien <julien.malik at c-s.fr>
>>>> Date: 2011/6/23
>>>> Subject: [Qgis-user] Re: [Qgis-developer] qgis-saga-python bindings in
>>>> ubuntu
>>>> To: "cavallini at faunalia.it" <cavallini at faunalia.it>
>>>> Cc: qgis-user <qgis-user at lists.osgeo.org>, qgis-developer
>>>> <qgis-developer at lists.osgeo.org>, Agustin.Lobo at ija.csic.es
>>>> For ubuntu, you are probably looking for this :
>>>> https://launchpad.net/~johanvdw
>>>> Julien
>>>> Quoting "cavallini at faunalia.it" <cavallini at faunalia.it>:
>>>> > A debian plugin is under preparation. Otherwise you'll have to build
it
>>>> > yourself.
>>>> > All the best.
>>>> > http://faunalia.it/pc
>>>> > ----- Reply message -----
>>>> > Da: "Agustin Lobo" <alobolistas at gmail.com>
>>>> > A: "qgis-user" <qgis-user at lists.osgeo.org>, "qgis-developer"
>>>> > Oggetto: [Qgis-developer] qgis-saga-python bindings in ubuntu
>>>> > Data: gio, giu 23, 2011 07:04
>>>> > Does anyone know if there is any way to get the required (by the qgis
>>>> > saga plugin) python bindings for the binary distribution of
>>>> > saga for debian and ubuntu?
>>>> > Thanks
>>>> > Agus
>>>> > _______________________________________________
>>>> > Qgis-developer mailing list
>>>> > Qgis-developer at lists.osgeo.org
>>>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> This message was sent using IMP, the Internet Messaging Program.
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> UbuntuGIS mailing list
>>> Ubuntu at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/ubuntu
>>> http://trac.osgeo.org/ubuntugis/wiki
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20110628/e73a8afd/attachment.html
