[Qgis-developer] ESA Summer of Code In Space
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Wed Jun 29 14:30:34 EDT 2011
Hi Andreas
> It is probably a gdal option when loading the raster into QGIS and when
> redrawing the raster.
It would be great to have a GDAL option for resampling. However, I don't think
there is one.
UMN mapserver seems to do the resampling in 'mapresample.c' (so on top of
GDAL).
Regards,
Marco
Am Mittwoch, 29. Juni 2011, 18.49:03 schrieb Andreas Neumann:
> no - I am not suggesting to implement this in the GdalTools plugin.
> QGIS uses gdal to load the raster, doesn't it? The QGIS raster loader
> should have an option to specify the resampling method used for the
> raster display. It is not the idea to generate new files with a
> different resampling method (like gdal_warp/gdal_translate do).
> Andreas
> On Wed, 29 Jun 2011 17:48:41 +0200, Paolo Cavallini wrote:
> > Il giorno mer, 29/06/2011 alle 14.04 +0200, Andreas Neumann ha
> > scritto:
> >> one idea that comes to my mind which is missing in QGIS rasters:
> >> Do you think that the ESA summer of code project could sponsor this?
> > Anyway, this should be an easy task, within the GdalTools plugin.
> > Any takers?
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Churerstr. 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
