[Qgis-developer] Copy of QGIS-NaturalEarth-Example.qgs, etc. -
Sample files for QGIS (Map) Server.
Noli Sicad
nsicad at gmail.com
Wed Jun 29 21:18:09 EDT 2011
Hi Alex,
The qgis projects are unusable without the data set.
Any further instruction how get the date set synch with the project?
If I download the natural earth data?
Any possible download link with copy of the data set that comes with
the qgis project e.g. NaturalEarth?
I am trying to figure out the install_gisdata.sh. I am using the a Mac
OS X. The script is bit tricky for Mac OS X since it design for linux.
I see "POSTGRES_USER="user" ? It needs Postgresql?
Thanks.
Noli
On 6/30/11, Alex Mandel <tech_dev at wildintellect.com> wrote:
> Yup, they are all in the same svn folder. The other 2 examples are
> dependent on I believe the Spearfish (might by NC) dataset from GRASS
> and the Mapserver Itasca example that ships with mapserver.
> We are including an OSM (.osm) file now (location changes yearly to
> match FOSS4G), and a populated Postgis database (OSM and NaturalEarth).
> It might be good to create a couple more examples using that data.
> Thanks,
> Alex
> On 06/29/2011 05:54 PM, Noli Sicad wrote:
>> OK.
>> I got the other 2 qgis project examples.
>> Thanks.
>> Noli
>> On 6/30/11, Noli Sicad <nsicad at gmail.com> wrote:
>>> Hi Alex,
>>> Thanks for info and the link.
>>>> http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/app-data/qgis/QGIS-NaturalEarth-Example.qgs
>>>> As for the data that comes directly from NaturalEarthData.com , details
>>>> are in the gisdata script:
>>>> http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/install_gisdata.sh
>>>> Note: there are 3 example qgis project files on the DVD currently.
>>> Would it be possible to send me the link of other 2 qgis project files
>>> example?
>>> Thanks in advance.
>>> Noli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
