[Qgis-developer] Copy of QGIS-NaturalEarth-Example.qgs, etc.
- Sample files for QGIS (Map) Server.
Alex Mandel
tech_dev at wildintellect.com
Wed Jun 29 21:38:17 EDT 2011
No you don't need postgres, we happen to duplicate the data into a
postgis copy as well as the native shp.
Basically the script makes a folder called:
/usr/local/share/data/natural_earth
Into that folder the various selected layer are downloaded from:
BASE_URL="http://www.naturalearthdata.com"
LAYERS="
cultural/$SCALE-populated-places-simple
cultural/$SCALE-admin-0-countries
cultural/$SCALE-admin-1-states-provinces-shp
cultural/$SCALE-urban-area
physical/$SCALE-geography-regions-polys
physical/$SCALE-geography-regions-points
physical/$SCALE-geography-regions-elevation-points
physical/$SCALE-geography-marine-polys
physical/$SCALE-land
physical/$SCALE-ocean
physical/$SCALE-lakes
physical/$SCALE-rivers-lake-centerlines
Where scale in this case is 10m.
To put an example together:
http://www.naturalearthdata.com/cultural/10m/10m-populated-places-simple.zip
You really only need about line 57-131, plus a couple of the variables
set at the top.
You could also probably get away with just looking at the example file
and seeing which layers it wants and just download those directly from
the Natural Earth website.
Thanks,
Alex
On 06/29/2011 06:18 PM, Noli Sicad wrote:
> Hi Alex,
> The qgis projects are unusable without the data set.
> Any further instruction how get the date set synch with the project?
> If I download the natural earth data?
> Any possible download link with copy of the data set that comes with
> the qgis project e.g. NaturalEarth?
> I am trying to figure out the install_gisdata.sh. I am using the a Mac
> OS X. The script is bit tricky for Mac OS X since it design for linux.
> I see "POSTGRES_USER="user" ? It needs Postgresql?
> Thanks.
> Noli
> On 6/30/11, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> Yup, they are all in the same svn folder. The other 2 examples are
>> dependent on I believe the Spearfish (might by NC) dataset from GRASS
>> and the Mapserver Itasca example that ships with mapserver.
>> We are including an OSM (.osm) file now (location changes yearly to
>> match FOSS4G), and a populated Postgis database (OSM and NaturalEarth).
>> It might be good to create a couple more examples using that data.
>> Thanks,
>> Alex
>> On 06/29/2011 05:54 PM, Noli Sicad wrote:
>>> OK.
>>> I got the other 2 qgis project examples.
>>> Thanks.
>>> Noli
>>> On 6/30/11, Noli Sicad <nsicad at gmail.com> wrote:
>>>> Hi Alex,
>>>> Thanks for info and the link.
>>>>> http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/app-data/qgis/QGIS-NaturalEarth-Example.qgs
>>>>> As for the data that comes directly from NaturalEarthData.com , details
>>>>> are in the gisdata script:
>>>>> http://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/bin/install_gisdata.sh
>>>>> Note: there are 3 example qgis project files on the DVD currently.
>>>> Would it be possible to send me the link of other 2 qgis project files
>>>> example?
>>>> Thanks in advance.
>>>> Noli
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
